Aficio MP C2050 Feed roller not turning (motor is)
  • theengel
    • Nov 2011
    • 1784
    Working on an Aficio MP C2050 and the feed roller for tray 1 is not turning. The motor is turning, but not the roller. Is there some kind of clutch or one-way bearing behind there that goes out? I can't find a parts manual so I'm not sure what to order to fix it. And taking it all apart looks like a daunting experience. I only want to do it once, when I have the actual part to replace.
    Any help is appreciated.
  • totoro
    • 568
    Re: Aficio MP C2050 Feed roller not turning (motor is)
    This should help you figure out what you need to order.troubleshoot paper jams.pdf
    I hope this helps.
    Totoro
      • 37458
      Originally posted by totoro
      This should help you figure out what you need to order.[ATTACH]28006[/ATTACH]
      I hope this helps.
      Items A and C on page 7 of the Trouble shooting guide totoro attached are spring clutches for the feed rollers. When they fail, you get the problem you are having. Items E and F are also spring clutches for the transport rollers.
