ricoh 2035e dead machin
  • hooman23
    • Jul 2014
    • 57
    my ricoh copier suddenly went off. and it does not turn on. when i tried to turn it on.it just blink less than one second. nothing happen after that... any suggestion?
  • allan
    RTFM!!
    • 5462
    Re: ricoh 2035e dead machin
    Start unplugging connectors for non crucial things like the fuser, or anything from the power supply and IO control that does not affect the controller from booting. Sounds like the supply is cutting out.
    Could be anything.
    If the problem, still persists swop out the supply if that does not work start swapping boards starting with the controler.
    Whatever
    • ruben
      The New Guy
      • Oct 2012
      • 1204
      From Goose's Guide:
      B135/B138/B182/B183 DEAD MACHINE, NO OPERATION [dead machine] - replace PSU
      B135/B138/B182/B183 DEAD MACHINE, NO OPERATION [dead machine] - replace BICU board
      B135/B138/B182/B183 DEAD MACHINE, NO OPERATION IOB to BICU ribbon cable not connected correctly
      B135/B138/B182/B183 DEAD MACHINE, NO OPERATION Shorted sensor - Photo reflection sensor AW010049
      B135/B138/B182/B183 DEAD NO POWER blown fuse 5 on copier power supply
      • vargue
        • Oct 2011
        • 404
        hi controller pcb harness too dusty or unreachable.clean with akai or some thing .it's happened only in 2035s
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          (Taps playing in background) bury it!!!!!!!!!!!!!!!
          Mystic Crystal Revelations
          • Iowatech
            Not a service manager
            • 3930
            Check where the power cord goes into the back of the machine. Maybe try plugging the machine into a different wall socket.
            • hooman23
              • Jul 2014
              • 57
              thanks all.. i think the problem is psu. i found someone to repair the psu.... by the way my 2035 doesnt have pcb
              • Zaxxon
                • 608
                A 2035 without any pcb...that's cool
                Please start you post with brand, model, problem.
                • wester
                  • Aug 2009
                  • 113
                  Hmmmm. How'dthey do dat?
                  • Tonerbomb
                    • Feb 2005
                    • 2589
                    AutoMajical resolution !!!!!!!!!!!!!!!!!!!!!!!!!!!
                    • hooman23
                      • Jul 2014
                      • 57
                      the problem was not psu.. i just replaced relay sensor and machine turned on... funny solution that i found by chance
                      • Tonerbomb
                        • Feb 2005
                        • 2589
                        Happy too hear you fixed it!!!!!!!!!!!!
                        • sandmanmac
                          • 3990
                          Only for a day or so......
                          http://www.copytechnet.com/forums/ri...coh-2035e.html
