ricoh 2035e dead machin
  • sandmanmac
    replied
    Re: ricoh 2035e dead machin
    Originally posted by Tonerbomb
    Happy too hear you fixed it!!!!!!!!!!!!
    Only for a day or so......
    http://www.copytechnet.com/forums/ri...coh-2035e.html
  • Tonerbomb
    replied
    Originally posted by hooman23
    the problem was not psu.. i just replaced relay sensor and machine turned on... funny solution that i found by chance
  • hooman23
    replied
  • Tonerbomb
    replied
    Originally posted by wester
    Hmmmm. How'dthey do dat?
    AutoMajical resolution !!!!!!!!!!!!!!!!!!!!!!!!!!!
  • wester
    replied
    Originally posted by Zaxxon
    A 2035 without any pcb...that's cool
  • Zaxxon
    replied
    thanks all.. i think the problem is psu. i found someone to repair the psu.... by the way my 2035 doesnt have pcb
  • hooman23
    replied
  • Iowatech
    replied
    Check where the power cord goes into the back of the machine. Maybe try plugging the machine into a different wall socket.
  • Tonerbomb
    replied
    (Taps playing in background) bury it!!!!!!!!!!!!!!!
  • vargue
    replied
    hi controller pcb harness too dusty or unreachable.clean with akai or some thing .it's happened only in 2035s
  • ruben
    replied
    From Goose's Guide:
    B135/B138/B182/B183 DEAD MACHINE, NO OPERATION [dead machine] - replace PSU
    B135/B138/B182/B183 DEAD MACHINE, NO OPERATION [dead machine] - replace BICU board
    B135/B138/B182/B183 DEAD MACHINE, NO OPERATION IOB to BICU ribbon cable not connected correctly
    B135/B138/B182/B183 DEAD MACHINE, NO OPERATION Shorted sensor - Photo reflection sensor AW010049
    B135/B138/B182/B183 DEAD NO POWER blown fuse 5 on copier power supply
  • allan
    replied
    Start unplugging connectors for non crucial things like the fuser, or anything from the power supply and IO control that does not affect the controller from booting. Sounds like the supply is cutting out.
    Could be anything.
    If the problem, still persists swop out the supply if that does not work start swapping boards starting with the controler.
  • hooman23
    started a topic ricoh 2035e dead machin
    my ricoh copier suddenly went off. and it does not turn on. when i tried to turn it on.it just blink less than one second. nothing happen after that... any suggestion?
