Ricoh MP 5002 Developer Change (Entering lot number)
  • Doug James
    • Jan 2012
    • 935
    [Misc] Ricoh MP 5002 Developer Change (Entering lot number)
    I am changing the developer for a Ricoh MP 5002. I can't find the manuals which I really need (I miss Paul) Am having trouble entering the lot number to set the TD sensor in the developer set up. I have entered every number I can find and it still won't execute the set-up. Any help will be soo appreciated...
  • logrady2331
    • Feb 2011
    • 301
    Re: Ricoh MP 5002 Developer Change (Entering lot number)
    You can put any number in there you want. The lot number is for Ricoh tech support when you call a problem in. You can just put the date in: example (021515) hit the # key, execute, yes, off you go. Be SURE to either take the toner hopper out or put a piece of paper between the drum unit outlet and developer unit inlet to block any toner from falling out of the hopper and over toning the new developer.
    • logrady2331
      • Feb 2011
      • 301
      PM me and I will do you a solid with the parts and service manual since you are a fellow Okie. I grew up in Lawton and worked in Stillwater before moving to Arizona.
      • slytukana
        • Feb 2015
        • 48
        Bizhub
        • slytukana
          • Feb 2015
          • 48
          Hi guys thanks for joining you.
          I had a problem with bizhub 195 . It displays "bios mode" when I switch on the machine and I try installing the FW it says the device is not ready.
