Ricoh 9002 ADF accordian jams intermittently
  • myxer1234
    • Feb 2013
    • 27
    Customer has issue with ADF. She says it will accordian fold the first document through the ADF often. Doesn't matter if it's 1 sheet or 50 sheets. These are just 20lb. paper, never been stapled. I can't ever duplicate the problem but I see they have tons of ADF jams on the SMC report. Sometimes 5 in a day sometimes 500 between jams. Have replaced the rollers and belts as well as one way clutches and torque limiters. Sensors test good but that doesn't mean much when it's working. Anybody have this issue?
  • techsass
    • Dec 2010
    • 248
    Re: Ricoh 9002 ADF accordian jams intermittently
    I haven't seen or heard of it on the 02 series, but the 01's had an issue with accordion jams at the belt.
    6001 DF reg roller jam.pdf
    • 1nevster
      • Dec 2010
      • 49
      If its happening later in the d.f. I have seen the slit glass fitted the wrong way around and the dust seal catch the paper. Can't visualise this d.f./ slit glass combination properly without being in front of one though sorry.
      • tufbnme
        • 493
        Replace the transport drive motor. Had them bad on the 01 series.
        • copyaction
          • Oct 2007
          • 988
          check that the slit glass is not upside down.
          • bamafan79
            I have had luck with bending the cover latch post down so it puts more pressure on the feed asy.
