Just in case any of you guys cop for one of these chunks of shit doing this. The scanner upper cover must be replaced. It's part number is M099 1757. The RM is too large for me to attach as a file.
SP3510 Void Lines from Scanner
Hit it.Tags: None -
Re: SP3510 Void Lines from Scanner
I quite like this model as a small home office MFD.
Like the previous range it does have a minor problem where the glue lift's where the white plate is.
That normally causes copying and scanning to be light down one side as the CCD cannot calibrate correctly.
Easy fix though.- Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
Fully qualified technician for Ricoh - Canon - Sharp - HP - Brother - Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
