MP301
  • Bennybhoy
    • Sep 2014
    • 5
    MP301
    Anybody had an issue with these toys leaving tram lines on the backs of copies due to the exit unit. If so, did you get around it, Cheers
  • rosspt
    • Mar 2012
    • 92
    Re: MP301
    Not a common problem as far as I know. The 161,171,201, and 301 are nearly identical so you're probably either looking at a fusing unit issue or image transfer roller issue.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Re: MP301
      If you are 100% sure it is paper exit, then you should try removing the fuser unit (which includes the paper exit assembly) and try it in another machine.
      It could be a dirty LFR or PTR.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Re: MP301
        Filthy little machines so it's most likely grubby ptr as Ruben said
