For Your information - FW names
  • Zaxxon
    • 608
    This table was new to me:
    The following chart shows the multiple names used to describe the same firmware.
    Firmware: Also Known As:
    BICU BICU
    Engine Engine
    Engine SBCU
    Fax Fax
    Fax Fax Application
    FAX(Option) RFAX
    Font EXP Summary Font
    GWFCU MBU
    GWFCU3-3(WW) FCU
    Music Music
    Network Doc Box Netfile
    Network Doc Box NFA
    Network Support NCS
    Network Support Netfile
    Network Support Network Support
    Network Support NIB
    Ope Panel LCDC
    Opt SD Scanner Scanner
    Option PS3 Post Script
    PowerSaving Sys SubSystem
    PS3 PS3
    RemoteFAX RFAX
    Scanner IPU IPU
    SD Printer Printer
    SD#1 Printer Printer
    Security Module DESS
    system GW System
    System/Copy Controller
    System/Copy Main Unit Controller
    System/Copy System
    Web Support Web Sys
    Please start you post with brand, model, problem.
