Internet Fax on Aficio MP 161
  • mtebka
    • Dec 2013
    • 38
    [Misc] Internet Fax on Aficio MP 161
    I am trying to set up internet fax on Mp161. I have programmed everything. The machine can do internet fax but the customer does not want any text in the message body. The message is:-
    "This E-mail was sent from "RNPCF76DB" (Aficio MP 161).
    Scan Date: 11.02.2015 08:04:46 (+0100)"
    Can anyone please tell me how to disable this notification because I have tried everything possible using Web Image Monitor (WIM) without any success. Thank you
  • mikedci
    • Jul 2010
    • 227
    Re: Internet Fax on Aficio MP 161
    Not sure if the MP 161 has these settings but check the WIM under configuration > scanner > send settings...look for insert additional info. there is a check box to turn this off or on.
    • mtebka
      • Dec 2013
      • 38
      unfortunately the 161 does not have the scanner send settings on WIM. The feature is you mentioned is on the MP 171.
