Ricoh MPC-2050 not connected in the network
  • kalaris
    • 70
    Hi. I have a mpc-2050 networked with cable cross on laptop does not see the network, no ping, although the LEDs of LAN port are both accesi.Stampa only connected with usb. I also replaced the controller card, and updated the firmware. No results. Any advice? Thank You
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh MPC-2050 not connected in the network
    If you are directly connecting between the copier and PC make sure that they are both set to static IP on the same subnet and IP range. You cannot use the same IP range of another network, if the PC is connected wirelessly for example.
    Find out if the PC is connected to another network (let's say it is on 192.168.1.x range), and use a different class network (10.0.0.x or 172.16.0.x).
    For the copier enter 10.0.0.1 with a subnet of 255.255.255.0, leave all other IPs as 0.0.0.0 (DNS, gateway, etc), and remove any domain information.
    For the PC enter 10.0.0.2 with a subnet of 255.255.255.0, leave all other IPs as 0.0.0.0 (DNS, gateway, etc), and remove any domain information.
    The copier can now only be seen by the PC it is directly connected to.
    • kalaris
      • 70
      I connected the pc as other copiers previously. With a mpc 2000 runs quietly but when I give the same port 2050 does not see it. The parameters are accurate both in the car and on the PC.
        • 37491
        Check that it does not have a wireless or Blue Tooth interface installed.
        Check 5985-001, it should be set to 1. If set to 0, network is disabled. If set to 2, WIM and some other features are disabled.
        • kalaris
          • 70
          The machine does not have a bluetooth interface or wi-fi only lan. I have already occurred and is 5,985,001 to 1.
          • Elmo
            • Feb 2010
            • 541
            can you post a copy of the config report for the machine
            I Used To Live To Fix Things Now i Fix Things To Live
            • MOSSY BOY
              • Aug 2010
              • 16
              Try reseting network port settings. Set Network security settings to level "0" in Administrator settings.
              • kalaris
                • 70
                Hi. I solved the problem by replacing the two NVRAM of the controller board. Thanks anyway to all
                • skynetto
                  • Sep 2012
                  • 257
                  Another one that use a bazooka to kill a bee.
                  • bob marley
                    • Jan 2012
                    • 1339
                    Ha Ha . not one bazooka but two at the same time
                    Live for yourself and you will live in vain. Live for others, and you will live again
