Function Problem in MPC3300
  • Wind Cool
    • May 2014
    • 82
    Hi, Guys.
    Have you all facing this problem in MPC3300?
    Come out function problem but does not show SC Code.
    need some help.
  • Moza
    • 232
    Re: Function Problem in MPC3300
    Originally posted by Wind Cool
    Hi, Guys.
    need some help.
    Thank you~[ATTACH=CONFIG]28166[/ATTACH]
    If you check SC History in SP 7403 it will tell you the last 10 error codes
    • Elmo
      • Feb 2010
      • 541
      do not factory reset
      follow Moza's advise look for any sc codes
      this type of issue can sometime be caused by HDD failure
      you could try formatting the HDD remember this will clear any data on the HDD (ie Address book etc)
      I Used To Live To Fix Things Now i Fix Things To Live
      • teebee1234
        • Jul 2008
        • 1670
        You can also disable auto reboot using sp5-875. Set 001 to "1" and 002 to "0" -reboot the machine. The SC code will be displayed immediately going forward.
        • Wind Cool
          • May 2014
          • 82
          Thank you everybody, I go back and try.
          Feed back when any result.
          Appreciate for your help.
          • Max
            • Oct 2011
            • 569
            Had the same on b/w copier, after f/w u/g worked fine.
