When I run duplex the 2nd side is way off(7 to 8mm). First side ok. Reg. off for all trays when duplexing on 2nd side only. Tried sp1001-13 and only adjusts first side. What am I missing?
MPC5000 duplex regestration off
Re: MPC5000 duplex regestration off
Duplex margin shift is ALWAYS set as default. (annoying)
Set all the settings to "0" in User tools. (I think there's 3)
Not sure of the exact location, but it's under User tools / Copier features/... -
Good thinking but I already set them to "0". By the way, I opened the side door to check sensors and any abnormalities shut the door and all is well! I have no idea why but the registration is back to normal. Good but bad situation I thinks!!!Comment
Have you tried the adjustments in the 6-xxxx, if the problem is showing up when using adf.Comment
Going back in the morning because like I thought the problem is back. I'm going to replace the whole duplex door and registration sensor to hopefully get in and out. I let everyone know what I find out.Comment
Well well well.... who ever heard of a customer using rotate sort with a SR3020 finisher! geez!!! After finding out how the customer was running her copies all that was wrong was the lead edge duplex adjustment in the RADF. Because the copies where coming out long ways with the line down the side of the paper I didn't even think about rotate sort!Thanks everyone for your input!
