cs 450 and paper jam all trays ricoh 2035e
  • hooman23
    • Jul 2014
    • 57
    copier machine went off and i found out behind the IOB board full of toner i replaced IOB board but machine didnt turn on until i had to replace registration sensor.. but paper from all trays cannot pass the registration sensor.. they jam before registration roller.. at the same time i have cs 450 that related to development motor..
    I also ran 5804 and i didnt hear click sound from running 5804040 related to development clutch and running 5804032 gave me cs450 that's related to development motor.
    tomorrow im going to replace development motor but i dont know where the development clutch is ..
    any suggestion for these confusing problems
    thanks
  • sandmanmac
    • 3981
    Re: cs 450 and paper jam all trays ricoh 2035e
    Let me guess...it's this same 2035e??
    http://www.copytechnet.com/forums/ri...ht=#post458276
    Seriously, you should take Tonerbomb's advice and bury it!
    Dev Motor is your problem - at least until tomorrow
    • hooman23
      • Jul 2014
      • 57
      yea its the same 2035e . the problem wasnt psu . it was my mistake. the problem was registration sensor.. when i replaced the sensor machine turned on....
      i have one 1045 and two 2035
      i use one 2035's spare part for other machines
      i have these kind of confusing problems after every 100K .
      • TonerMunkeh
        Professional Moron
        • 3865
        These machines are well past their sell by date now. Bin them asap, you'll be able to pick up 4000/5000's dirt cheap now.
        Hit it.
          • 37529
          Final month of assured parts availability was February 2011. Find a cliff somewhere and push it off.
          • hooman23
            • Jul 2014
            • 57
            thanks for all helps and hopes that you mates gave me
            • Bantams
              • Jun 2012
              • 603
              A Seized up Dev unit is more likely than the actually motor if you remove the dev unit / pcu can you turn the gear?
              If not replace it.
              • bob marley
                • Jan 2012
                • 1339
                s
                There is no dv clutch on 2035e , there is only development drive unit ass'y ( part no B082 1142 )
                I think there is overload caused by that amount of toner behind the IOB . check drive section
                specially the two ball bearings on the gear shaft behind the relay clutch
                Live for yourself and you will live in vain. Live for others, and you will live again
                • hooman23
                  • Jul 2014
                  • 57
                  Development motor cable was disconnected .thats why machine cloud not pick up the paper. i had cs450 before this problem so i replaced development motor and TRAY LIFT MOTOR anyway... cs 450 completly solved.. paper pick up solved.. but every 20 or 30 copies paper jam around registration roller . paper twist around registration roller
                  im not sure but i think its registration sensor .((last time machine went off because of faulty relay sensor))
                  any suggestion ?
                  thanks
                  • hooman23
                    • Jul 2014
                    • 57
                    finally i have found the solution . im going to another 100k . until... registration sensor and relay sensor were defective... toner spilled under registration roller and behind the Motor control board .. i replaced the relay and registration sensor.. i wasnt sure about the Motor control board but replaced it. im going to replace the drum and developer seal to prevent toner soiling .
