Problem with RICOH DF 3010
  • tecnomarco
    • Jul 2011
    • 214
    HELP .. Greetings to all I have a problem with the power supplies of the original DF 3010 mounted on the RICOH MP C3500 / 4500/4000 jam, I performed dismantling and cleaning of all the rubbers with poor results, has anyone had experience ... and know what you should do?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Problem with RICOH DF 3010
    Is the connect on the the main copier body broken? These do break very frequently.
    • tecnomarco
      • Jul 2011
      • 214
      thanks for having responded Ruben can make me better understand what is broken
      • tecnomarco
        • Jul 2011
        • 214
        I was wrong to explain
        • tecnomarco
          • Jul 2011
          • 214
          the problem is JAM to DF3010 the rubber are clean but the JAM si much frequently
          • Max
            • Oct 2011
            • 556
            So is it jamming or problem with the power supply? Cant quite understand...
            • tecnomarco
              • Jul 2011
              • 214
              The problemi si jamming
