Cleaning unit MPC 8002 / 6502
  • Timmytronic
    • Oct 2010
    • 249
  • Max
    • Oct 2011
    • 546
    Re: Cleaning unit MPC 8002 / 6502
    I think the pm counter is just a reminder of the parts life. You need to reset the rotation counters. Only had Ricoh training on MPC6500 so 6502 may be a tad different.
    • Timmytronic
      • Oct 2010
      • 249
      I thought that but can't see those counters, there are some in the PM counts as in Percentage which is now at Zero, so not sure where else to go.
      • freginold
        • Sep 2010
        • 102
        If you've already reset the counters, check the lube bar sensors themselves. If the actuator isn't positioned properly, it won't actuate that switch and it will think the lube bar needs to be replaced. You can check the two sides of the switch with a meter to be sure it is situated correctly.
        Also check TSB 113 for more info on those sensors.
        Config page instructions for copiers, printers, & fax machines
        • Timmytronic
          • Oct 2010
          • 249
          Hiya
          Thanks for that. I have had a try and sensors are fine and working. They are not actuated, so meaning the lug bar has not actuated the switch. I have even spoken to Tech support and they don't know either but just fitting a whole new unit, just frustrating to know how a new unit will make it work.
          Thank you.
          • Timmytronic
            • Oct 2010
            • 249
            Just in interest, I have taken the connector off for the Cyan which is not due anyway and it has not said anything about it, so it must be a reset in the machine somewhere I guess.
            • Gamut
              • Jul 2008
              • 216
              must be cleared in SP3xxx manual parts reset until you update firmware.
              • Timmytronic
                • Oct 2010
                • 249
                Hi Gamut
                SP3 is process, have you the full SP number to get to, to reset please? I don't have Access to Firmware at this time but I don't care doing a manual reset.
                Thank you.
                Tim
                • Timmytronic
                  • Oct 2010
                  • 249
                  Originally posted by Timmytronic
                  Hi Gamut
                  Thank you.
                  Tim
                  Hi Gamut
                  Found it, and it worked :-) Thanks loads. I will try and get the Firmware update for that.
                  • pauloorechio
                    Hi Gamut
                    • semi
                      • Sep 2008
                      • 192
                      Reset parts counter in SP 7622 for cleaning unit(or somewhere round there) with bypass door open
