MPC 7501 sc565
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    MPC 7501 sc565
    Hi all.
    I have MPC7501 that lately has been giving sc 565(normally first thing in the morning) Lamps have been metered (ok) and thermistors cleaned and thermostats checked out ok.
    If i reset the code the machine runs until the next call ( a few days or next day)
    I am ordering a temp sensor (upper thermistors) and upper themostats.
    Has anyone else had this issue on this model?
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • semi
    • Sep 2008
    • 195
    Re: MPC 7501 sc565
    Yep,fusing lamp connectors wrong (colours wrong way round),anybody change the belt recently?
    • yasir
      • Mar 2007
      • 19
      Re: MPC 7501 sc565
      Originally posted by leo34staffs
      Hi all.
      also i have SC 555 with ricoh 7502 every morning ,used to run 58012# cleared but comes next day wonder ?
        • 37644
        Re: MPC 7501 sc565
        A dirty or out of position thermistor can cause fusing error codes. Many times a fusing error code when a machine is first turned on in the morning results from the room temperature dropping below 60 F for an extended period of time. try connecting the upper and lower tray heaters to keep the inside of the machine warmer.
