Scan to Email
  • Ricoh-ono
    • 339
    Scan to Email
    I have a LD015spf that scans successfully to email if it is the first scan job. Any subsequent scans that are attempted after the first job cause the scanner to hang up and eventually error out. I have to cycle the power on the machine in order to scan to email. ScanRouter v2 Lite works all day long. Memory clear has been done on the scanner application but has not resolved the problem. Any ideas?
    Do what you can, with what you have, where you are. ~Theodore Roosevelt
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Firmware first!
    Mystic Crystal Revelations
