misprint ricoh sd card 1357EX
  • Brudu
    • Jan 2013
    • 11
    I have a problem with the ricoh 1357EX. to put the sd card printing the printer is very slow and does not enable the print module. not print with the sd card.
    my doubt is if the problem is in the sd card, or some printer setup.
    the printer screen says you need to change the system, will be the problem in the system itself?
  • sandmanmac
    • 3981
    Re: misprint ricoh sd card 1357EX
    [ATTACH=CONFIG]28250[/ATTACH]
    The system says change the supply​.............PAPER!
    • Brudu
      • Jan 2013
      • 11
      and the problem of sd card printing. the machine does not appear the print module
        • 37449
        The Production Pro 907EX, 1107EX and 1357EX do not have an option for USB2.0/SD SLOT TYPE C. The SD slots on the back are for options and firmware upgrades. Currently there is no option that I am aware of that use the USB host slots. As the next generation of Production machines are now out, I doubt if Ricoh has any desire to add any additional options to the older models.
        • Brudu
          • Jan 2013
          • 11
          my doubt is. the copier is not enabled the print module.
