error code in ricoh 7502 Sc 555
  • yasir
    • Mar 2007
    • 19
    [Error Code] error code in ricoh 7502 Sc 555
    the mentioned code comes daily we reset every day can any one help in this issue?
    if we replace the thremister the code cleared?
    yasirmohmed@yahoo.com
    • 37444
    Re: error code in ricoh 7502 Sc 555
    It could be the pressure roller thermistor. A dirty or out of position thermistor can cause fusing error codes. Many times a fusing error code when a machine is first turned on in the morning results from the room temperature dropping below 60 F for an extended period of time. try connecting the upper and lower tray heaters to keep the inside of the machine warmer.
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      The cleaning web was also modified to supply more oil to keep the hot roller surface cleaner so the thermistors don't get so clogged up with toner and paper dust.
      AE045069
      • techsass
        • Dec 2010
        • 248
        Get into SP mode & change the following:
        1105-2 to 180*
        1107-1 to 195*
        1107-2 to 195*
        1107-3 to 70 seconds
        1107-4 to 70 seconds
        2804 to OFF
        3904 to 2
