PDF save as A4 and A3 for printing
  • PA3040
    • Jun 2014
    • 171
    Dear All,
    One of our customer has PDF file that saved as some pages A4 and some pages A3 in single file. so he is requesting to print A4 from A4 paper cassette and A3 pages from A3 paper cassette
    Please advice can we do this automated cassette selection base on single PDF file but different paper size with RICOH macine
    Thanks in advance
  • Max
    • Oct 2011
    • 557
    Re: PDF save as A4 and A3 for printing
    If the driver and the copier is set to auto tray selection then it should automatically go for the correct tray.
    • PA3040
      • Jun 2014
      • 171
      Thanks for the reply
      But in the paper source we can select Auto select by printer but we must give the paper size
      any ideas
      • rthonpm
        • Aug 2007
        • 2853
        You may need to turn off the scaling options in Adobe Reader to get the pages to pull from the correct tray for multiple sizes, otherwise Reader will try to scale all pages to the size of the first page.
        Sent from my BlackBerry using the Android app.
        • PA3040
          • Jun 2014
          • 171
          Hi
          Can you please show the path that where the scaling option is existing
          My next question is ,
          We must select the one particular paper size in the paper tab in the printer driver menu, then how the printer controller decide other paper size
          In the paper source we can select auto tray selection but we can't set for auto paper selection for paper size.....Am I write?
          • rthonpm
            • Aug 2007
            • 2853
            It's on the first page of the Adobe print dialogue. I've attached a copy of the screen and highlighted the two things you likely want checked.
            I'd make sure to tell the user to NOT make this their default as it often causes issues with documents that just have one size documents. Also, make sure that the end device has the correct paper sizes listed in the driver so that Reader can make the correct choice on what tray to draw the paper from.
            • PA3040
              • Jun 2014
              • 171
              I will check and update
              Thanks again
              [ATTACH=CONFIG]28325[/ATTACH]
