MP 3500 SC 672
  • FuneralThirsty
    • Mar 2015
    • 6
    MP 3500 SC 672
    I have a Savin 8035e or Ricoh Aficio MP 3500 that will pop this code only after several hours of being on. I have replaced the Controller board, NVRAM, HDD, BICU, the entire Scanner unit, the little RAM stick, and the power switch. I seriously am lost on what's next. The code will show up after 4+ hours sometimes will be on all day at least 8 hours. We will get to work in the morning it will be there. Also the code evolved from an SC670, but went away after the controller board change. Should I do the I/O Board, High Voltage board, anything else???? Please and thanks
  • sandmanmac
    • 3981
    Re: MP 3500 SC 672
    Wow. Frustrating!
    Based on all you've done so far, I'd suggest reflashing FW, and making sure System FW is 1.51.3 or newer
    • PA3040
      • Jun 2014
      • 171
      Re: MP 3500 SC 672
      Originally posted by sandmanmac
      Wow. Frustrating!
      I think you can't enter the SP mode?
      Re fix all parts back to original state and replace new controller board and remove the old board NVRAM and fix to the new controller board
      How about the copy count?
      • sandmanmac
        • 3981
        Re: MP 3500 SC 672
        Say Whaaaat?
        Anyone else confused by this? Or is it just me?
        • FuneralThirsty
          • Mar 2015
          • 6
          Re: MP 3500 SC 672
          Copy count: 230,000
          I can't do any firmware because my company is no longer Savin dealers and are now Kyocera.
          and when SC 672 is on there is no SP access, but like I said it takes hours for it to pop up and the machine is completely functioning.
          • bob marley
            • Jan 2012
            • 1339
            Re: MP 3500 SC 672
            when u replaced the controller board did u also replace the PCB board ?
            Live for yourself and you will live in vain. Live for others, and you will live again
            • PA3040
              • Jun 2014
              • 171
              Re: MP 3500 SC 672
              Say Whaaaat?
              In our case we solved it
              Cheers
              • FuneralThirsty
                • Mar 2015
                • 6
                Re: MP 3500 SC 672
                I replaced the whole controller box from a known good working machine. Swapped NVRAM though. But we have tried new NVRAM since.
                • PA3040
                  • Jun 2014
                  • 171
                  Re: MP 3500 SC 672
                  I would not recommend to swap
                  You can remove and fix controller board four five time as i explained earlier
                  Good luck
