Help for faster print over network with aficio 1055
  • guitarloverasl
    • Mar 2015
    • 11
    Hello there ,
    Hope you are all doing great , we just got an aficio 1055 , it is in good shape and there is no problem with that , the only inconvenient we have with this machine ( I dont know if it could be fixed ) is slow print over network by using pc - we almost never use copy and we just need printing by pc and the network , all of our files are pdf files - the machine works well but it sends the print to machine very slowly I would say one copy in 3 sec or so - I checked and noticed that the sd rams it has on the printing board are 32 mg and 128 mg ( pcl 100 ) I tried and changed the 32 ram with the same 128 ram but no difference on the speed and receiving the prints from pc .
    is there any way I could make this machine printing faster over network?the interesting thing is that I know a store whose machine is an older famliy of this machine and it is 551 and they also print pdf files using pc and I suppose that could print faster as they print something around 7000 pages or so
    I would really appreciate any advice and help
    Thanks for your time
    • 37508
    Re: Help for faster print over network with aficio 1055
    A total of 160 MB is the maximum that can be used. There should be a setting in User Tools somewhere for the way the memory is used, font vs buffer. The buffer memory should be set to the largest available. As this model if obsolete and I don't have one to check, I cannot tell you exactly where the setting is. The main things that affect network print speed is the driver. Do not use a generic driver or a Windows supplied driver as they tend to be slow. In the printing preferences, check for settings for True Type fonts (download as true type or bit mapped) and for graphics type (raster or vector). Try changing these settings.
    • guitarloverasl
      • Mar 2015
      • 11
      Thanks for the answer , I tried and could not find any memory buffer -I am using win 7 and I have installed all the 4 drivers available for this specific model including
      1: PCL 6 Driver
      2:PCL 5e Driver
      3:PostScript3 Driver
      4:PCL Mini-Driver
      with driver 1 , 2 , and 4 I noticed when I send the files to print in the print statue I noticed the size of the printed pdf file is super huge (the orignal file is around 4 mg but when it is printing it shows the size around 500 mg!)
      strangely with driver number 3 I got super fast printing with the machine but it just sent white pages and at the start some pages of errors written in the printed page.
      any other help would be appreciated guys
      • guitarloverasl
        • Mar 2015
        • 11
        1: PCL 6 Driver
        2:PCL 5e Driver
        4:PCL Mini-Driver
        • guitarloverasl
          • Mar 2015
          • 11
          Thank you for the answer , I could not find any buffer regarding the print - the strange thing is that when I send the prints from the pc , the sent pdf files size get super huge sometimes - I am using all 4 kinds of its official drivers they have for this model from afficio's website - the PS driver sends super fast but just white pages and nothing more
          Cheers
          • qbert69
            • Mar 2013
            • 1152
            Check your ethernet port negotiation speed and make sure it is full duplex--not half duplex!
            Also the ballooning of your pdf's may have something to do with how the pdf was created!
            Any time I see someone with a problem, I ask how the pdf was created.
            PDF is a container format and can contain many types of objects and layers. If the PDF is in a single layer as if it is just an image, many times it will process faster. If it is slow in processing, perhaps it is due to multiple layers which have to be flattened before printing! Also having different image types in a pdf can cause problems, such as having a CMYK colorspace object in a mostly RGB colorspace PDF can cause a print delay.
            And definitely, make sure your print drivers are updated and correct for your printer and computer OS!!!
            REACH FOR THE STARS!!!
            Konica Minolta Planetariums!
            • guitarloverasl
              • Mar 2015
              • 11
              Thanks for the answer , I m printing the same pdf files in another machine (aficio 3045) and it is fine no problem - the speed is full duplex - I m facing problem using postscript 3 driver which I have downloaded from the official website for this specific machine , it is just printing some weird codes and english letters - what am I missing?with the other drivers the speed is very low
              Any other help will be appreciated
              thanks
              • Elmo
                • Feb 2010
                • 541
                I would say you are missing the post script option in the machine
                it is not fitted as standard you would need to buy the option
                it comes on and sd card which you fit to the machine
                I Used To Live To Fix Things Now i Fix Things To Live
                • guitarloverasl
                  • Mar 2015
                  • 11
                  Thanks for making it clear for me , so basically it is like a SD card I have to connect it to the machine?but where is the place for that on the machine , I cant find any place on the machine for the card to be fitted
                  • qbert69
                    • Mar 2013
                    • 1152
                    Yep!
                    More than likely missing the PostScript option!
                    It really pisses me off that Ricoh sees this an "option" rather than a requirement!
                    It would be nice if there was an IEEE consortium that REQUIRED printers to have certain things before being put on the market!--this case, PCL & PS...that's pretty much a "no brainer"!!!
                      • 37508
                      This machine was manufactured before Ricoh started using SD cards. Firmware updates required the use of a 4MB PCMCIA card special software for your laptop in order to write to the cards. Options were installed using either option cards that plugged into the controller.
                        • 37508
                        Originally posted by qbert69
                        Yep!
                        Adobe holds the copyrights to PostScript and requires a licensing fee on every printer with PostScript installed. It is this fee that makes the option cost as much as it does.
                        • qbert69
                          • Mar 2013
                          • 1152
                          hmmm.....
                          Why not have an "OpenPS"....an open post script community???
                          I know that several printer manufacturers, most notably HP has used an "emulated" PS on their machines, which I have used with Apple products and not had any problems to speak of!
                          • guitarloverasl
                            • Mar 2015
                            • 11
                            Thanks guys for the answers - so I should forget about postscript 3 for this machine , my only option is PCL 5e and PCL 6 - when I sent a pdf file using pcl 5 e ( the size of the original pdf is 1 mg) while spooling its size gets around 40 mg - is there any way to make the sent file size smaller so it loads faster?I can not make the PCL6 work I could install it successfully but when I send the file with that it says the document could not be printed.
                              • 37508
                              hmmm.....
                              This has not been around very long. Ricoh has tried it but we're not as happy with it as compared to Adobe.
