any clue please i take off transfer unit and clean carefully and code disappear for afew days and back again.
sc440 im mp9000
Tags: None
Re: sc440 im mp9000
Only two options
1) check harness of transfer unit to copier.
2) replace transfer power pack. -
Re: sc440 im mp9000
Sc 440 is Transfer Output Error
Description
One of the following conditions was detected for 17 counts (about 100 ms) when the transfer voltage was applied with the main motor operating:
• The value for the transfer current was set for 70uA, but the feedback voltage was less than 0.75V (less than 1.5 KV).
• When the feedback current was less than 0.16V (10uA), the feedback voltage was less than 0.15V (less than 300V) due to a poor input connection.
• When the feedback current was less than 0.16V (10uA), the feedback voltage was less than 3.05V (over 6.1 KV) due to a poor output connection
Causes
• Transfer power pack harness, connectors loose or broken
• Transfer power pack harness or connectors have short circuited
• Transfer power pack is defectiveLive for yourself and you will live in vain. Live for others, and you will live againComment
Re: sc440 im mp9000
check the harness most of the time its cut due to tilting up and down of transfer knob...fix the customer first then fix the machine... its simple and makes life more easy.Comment
