Aficio 240w problem
  • bat
    • Sep 2008
    • 140
    Aficio 240w problem
    Hi all...
    The machine is showing a ID sensor pattern on almost each print, even when Toner Supply Mode is set to Fix.
    image.pdf
  • ranachinna
    • Mar 2015
    • 11
    Re: Aficio 240w problem
    Originally posted by bat
    Hi all...
    [ATTACH]28341[/ATTACH]
    You check all sensors if you face again swap and check it
    • tjvincent
      • 280
      What have you done so far ?
      Did you try replacing the cleaning blade ?
      • ranachinna
        • Mar 2015
        • 11
        Are you check clean blade section
          • 37524
          Please attach a sample of the marks that you are talking about as the machine does not normally do a pattern every copy. My guess is that you have a bad drum.
          • Polarbear
            • Feb 2012
            • 1070
            Was the machine moved recently? There is a cleaning blade "park" lever below the drum (right hand side) of the frame.
            If it was not set in the correct direction, the cleaning blade does not touch the drum and you will get repeat prints (ghosting).
            Press the GREEN button!!
            • PA3040
              • Jun 2014
              • 171
              Clean the drum properly with water
              • rsyarcia
                Hair Straightener Tech
                • 711
                Push the cleaning blade release lever to the right. encountered this issue lot of times.
                Nobody is perfect..
