MP C4502 Hardrive size
  • ABS tect
    • Sep 2013
    • 511
    What is the Hardrive size for an MP C4502? And also how do you get into the sc mode on it?
    • 37365
    Re: MP C4502 Hardrive size
    Look on the label on the existing HDD
    Create an error on the machine. Or did you mean SP mode. If you meant SP mode, you should not be working on Ricoh equipment as it is common knowledge for all Ricoh qualified technicians.
    • ikerl
      • Cipher
        It's not easy being green
        • May 2006
        • 1309
        Originally the 4502 came with an 250Gb 2.5" SATA HDD but the official replacement part is now an 320Gb HDD.
        As long as the controller can detect the HDD, it should work.
