Aficio MP C4500, no can scan!
  • Jan Steinman
    • Mar 2015
    • 6
    I just got an Aficio MP C4500 from the BC Government, who seem to be getting rid of a lot of them all at once, so I'm hoping they aren't just dumping lemons.
    When I was putting it through its paces, I noticed that the "Scanner" button tried to bring up Java. I went into "Extended Feature Settings" -> "Change Allocation," and sure enough, Java had been assigned to the "Scanner" button. I cleared that allocation, and now the "Scanner" button does nothing.
    The copier works fine, and I can fax to disk, so the scanner hardware appears to be working fine.
    Looking at version.txt, it does not appear to have scanner firmware. I've seen other postings of firmware that listed "Scanner" on them. Am I reading this right?
    PartNo. Module Name Version Module ID
    B2215610A animation 1.00 APC1a_animation
    B2215605L Network Support 5.20 APC1a_net
    -------- Security Module 1.03 APC1a_DESS
    B2215602H Fax 03.00.00 APC1a_fax
    B2215601S System/Copy 1.70 APC1a_system
    B7355060 Data Erase Opti 0.03 GW2a_zoffy
    B2215606G Web Support 1.09 APC1a_web
    B2215608J NetworkDocBox 3.02 APC1a_netfile
    B2215609D Web Uapl 1.12 APC1a_webuapl
    B2215903E Fax(option) 03.00.00 APC1a_fax2
    B7675383 SD#1 PCL Font 1.00 GW1e_prt_fntM
    B8375601K SD Printer 1.70 APC1e_printer
    B8395601A PS3emu 1.01 APC1e_prt_PS3
    G1065932 PS3 FONT 1.00 GW3e_prt_psfnt5
    B8615200K libcvm(for 05A) 2.11 GW1a_libcvm
    B7715571D FCU 06.00.00 GW1a_efax_fcuG
    B2235117R Engine V1.64:01 APC1a_eplot
    B2231491B OpePanel 1.15 APC1a_epanel
    B2231496A LANG0 0.77 APC1a_elang
    B2231496A LANG1 0.77 APC1a_elang
    Also, I also went into SP mode, and SP-7-801-255 (Firmware Version) shows only dashes in both columns next to "Scanner".
    So, it seems I don't have firmware for the Scanner function, no? As far as I can tell, it's not an extra-cost option, or the button wouldn't be there, right?
    At this point, is there anything I (a retired electronics tech, but not credentialed with Ricoh) can do?
    Thanks for any advice offered! This is for a not-for-profit co-op organic farm, if that makes any difference. I'll give you some produce if you help me fix this! :-)
    • 37532
    Re: Aficio MP C4500, no can scan!
    The MP C4500 were first produced in June 2006. They are most likely replacing them and the company that they are buying from did not offer any trade-in.
    The MP C4500 originally came in three models, the MP C4500, the MP C4500spf and the MP C4500g. The C4500 and C4500spf come with both scan and print installed and the Product Support Guide does not show a Print/Scan option. The C4500g was for GSA purposes and I do not know if it had Print/Scan installed but the fact that the PSG does not show an available option means it probably did. If the machine also does not print, I would say that someone removed the SD card. Otherwise I would say that the scan function has been disabled. Check Scanner SP settings. Also check Security Settings in User Tools. Certain security settings disable a number of functions. Since this was a government machine, the security setting is most likely set to 2 or higher.
    • Jan Steinman
      • Mar 2015
      • 6
      Thanks for all the great information, slimslob!
      Yea, when I see one-off on the BC Auction website, I am hesitant. But there's been at least a dozen of these go through there recently. The first ones went for well over $1,000. I got mine for under $300. I guess you get what you pay for...
      Good info to know! Since these were owned by the British Columbia Government, I'm guessing they are the GSA model. The nameplate doesn't seem to indicate any sub-model. The WIM "Home" --> "Device Info" --> "Model Name" simply says "Aficio MP C4500".
      Yea, an SD card problem was on my list of things to investigate. But it prints fine. (Well, I'm still sorting out a persistent jam in the internal tray during duplexing...)
      There are no separate Scanner SP settings! The SP buttons are "Copy SP," "Fax SP," and "Printer SP," with an ominous space below where another button would fit. Under "Copy SP," there is a section labeled "Scanner" (SP-4XXX), but it doesn't show anything obvious for enable/disable. I will pour through the tech lit to see if any of the SP-4XXX functions might do me any good. I know better than to just go poking around changing things in there... :-)
      And there's a big empty hole in the User Tools buttons, in the same position that there's a hole in the SP buttons (below "Printer Features"). Which together with the "------------" entries on the firmware versions page, makes me think it is more serious than simply being disabled.
      If the my-ricoh.com admins decide to give me the keys to the candy store, will I be able to download and install the Scanner firmware without installing all the firmware? It appears it has to be in one big chunk, according to WIM --> "Configuration" --> "ROM Update".
      Would someone with access to a machine with a working "Scanner" button show a firmware version dump, like I did above? It seems that would pretty much indicate if I was missing the Scanner firmware.
      Feel free to "RTFM" me, if appropriate. (A starting point suggestion would be appreciated, though!) I've gone over all the user manuals, but have been saving the pleasure of reading the tech manuals for a rainy day...
        • 37532
        Since it prints, you may want to check the SD cards that are in the machine. Since it still had Java installed, there should be 2 installed. One will be the Java card, do not remove it without first stopping it in User Tools. The other should be the Print/Scan card. If it is labeled as Print/Scan, check to see if there is a parts number printed on it. Defective option SD cards can be replaced through parts.
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Slimslob is correct about stopping java through Extended features, however after you STOP the java app you need to reboot the MFP to complete the stop and then go back into extended features and UNINSTALL the feature, then shut down and remove the Java card. Also if you are not running any Java app's leave the card out, the machine doesn't need it if there are NO java apps running ...................
          Mystic Crystal Revelations
          • bob marley
            • Jan 2012
            • 1339
            Thank you so much for all of these very valuable information
            Live for yourself and you will live in vain. Live for others, and you will live again
            • Jan Steinman
              • Mar 2015
              • 6
              Many thanks to slimslob and tonerbob for their help!
              I've done an inventory, and find the following SD card info:
              1: 2-0708, B8375001K, 32MB
              2: 0708, 1B8390421848, PostScript 3, 32MB
              3: A0801, B8610601K, VM CARD, Type C, Java, 64MB
              Xtra: 0709,1B73518-4399B, DataOverwriteSecurity Unit Type D, handwritten on back: L907-682-0272
              The "Xtra" one was in the storage slots in the front.
              According to the training slides I downloaded, it seems there isn't supposed to be anything in Slot 3, which is reserved for installing firmware. Other service lit indicates that Java (in particular) should NOT be run from slot 3, but it must be downloaded. Also, the installation instructions for the Java card say to install an "Other Function" key cover in the sixth key slot. This machine has no sixth key. That and the hand-written part number on the extra SD card seems to indicate someone has dinked around with the SD cards.
              I can't find the handwritten number in any of the parts list. Does it mean anything to anyone?
              Anyway, unless having the VM CARD plugged in when slot 3 is supposed to be empty is screwing things up, it looks like the B837 SD card may be defective, meaning base software ("Scanner") that comes with every submodel is missing.
              If so, what can I do at this point?
              Can I tell for certain if the B837 card has had the scanning stuff deleted by looking at this card on a PC?
              Thanks again for any advice offered!
              • Jan Steinman
                • Mar 2015
                • 6
                The plot thickens...
                I found an SD Card reader, and copied all four cards for examination. Most interesting is the one from Slot 1, which is supposed to contain the print/scan stuff.
                The directory "module" appears to contain the actual firmware, and the stuff for the scanner function appear to be there:
                Code:
                # ls -la m*
                module:
                total 12148
                drwxrwxrwx  18 jan  staff      612 13 Aug  2007 .
                drwxrwxrwx  10 jan  staff      340 16 Mar 15:58 ..
                -rwxrwxrwx   1 jan  staff       64 12 Mar  2008 ZOFFY.MAC
                -rwxrwxrwx   1 jan  staff    90413 12 Mar  2008 ZOFFY.MOD
                -rwxrwxrwx   1 jan  staff       64 21 Jun  2011 fax.mac
                -rwxrwxrwx   1 jan  staff   793707 21 Jun  2011 fax.mod
                -rwxrwxrwx   1 jan  staff       64  3 Jul  2007 fonts_e.mac
                -rwxrwxrwx   1 jan  staff  1092966 16 Sep  2006 fonts_e.mod
                -rwxrwxrwx   1 jan  staff       64 21 Jun  2011 nfa.mac
                -rwxrwxrwx   1 jan  staff  2056706 21 Jun  2011 nfa.mod
                -rwxrwxrwx   1 jan  staff       64 21 Jun  2011 prt_exp.mac
                -rwxrwxrwx   1 jan  staff  3147777 21 Jun  2011 prt_exp.mod
                -rwxrwxrwx   1 jan  staff       64 14 Jun  2007 scan.mac
                -rwxrwxrwx   1 jan  staff   951742 14 Jun  2007 scan.mod
                -rwxrwxrwx   1 jan  staff       64  8 Jun  2009 websys.mac
                -rwxrwxrwx   1 jan  staff  2908329  8 Jun  2009 websys.mod
                -rwxrwxrwx   1 jan  staff       64 13 Aug  2007 webua.mac
                -rwxrwxrwx   1 jan  staff  1345024 13 Aug  2007 webua.mod
                Hmmm... the "gwinit.d" directory looks interesting... a bunch of .CNF/.LIC files in pairs... with the "scan.CNF" missing:
                Code:
                # ls -la g*
                gwinit.d:
                total 60
                drwxrwxrwx  17 jan  staff  578 13 Aug  2007 .
                -rwxrwxrwx   1 jan  staff   73 12 Mar  2008 ZOFFY.CNF
                -rwxrwxrwx   1 jan  staff   64 12 Mar  2008 ZOFFY.LIC
                -rwxrwxrwx   1 jan  staff   51  4 Feb  2007 fax.cnf
                -rwxrwxrwx   1 jan  staff   64 13 Aug  2007 fax.lic
                -rwxrwxrwx   1 jan  staff   47  3 Jul  2007 fonts_e.cnf
                -rwxrwxrwx   1 jan  staff   64 13 Aug  2007 fonts_e.lic
                -rwxrwxrwx   1 jan  staff   68 14 Jun  2007 nfa.cnf
                -rwxrwxrwx   1 jan  staff   64 13 Aug  2007 nfa.lic
                -rwxrwxrwx   1 jan  staff   47 13 Aug  2007 prt_exp.cnf
                -rwxrwxrwx   1 jan  staff   64 13 Aug  2007 prt_exp.lic
                -rwxrwxrwx   1 jan  staff   64 13 Aug  2007 scan.lic
                -rwxrwxrwx   1 jan  staff   93 13 Aug  2007 websys.cnf
                -rwxrwxrwx   1 jan  staff   64 13 Aug  2007 websys.lic
                -rwxrwxrwx   1 jan  staff   54 13 Aug  2007 webua.cnf
                -rwxrwxrwx   1 jan  staff   64 13 Aug  2007 webua.lic
                The .CNF files appear to hold a standard UNIX mount(8) command:
                Code:
                # cat prt_exp.cnf
                mount gzromfs module/prt_exp.mod /printer/sys
                Hey wait, what was that single file in the top level again?
                Code:
                # ls -la
                total 16
                drwxr-xr-x   7 jan  staff   238 16 Mar 15:56 ..
                drwxrwxrwx   3 jan  staff   102 13 Mar 05:16 cacert
                drwxrwxrwx   3 jan  staff   102 21 Aug  2007 dictionary
                drwxrwxrwx  17 jan  staff   578 13 Aug  2007 gwinit.d
                drwxrwxrwx  18 jan  staff   612 13 Aug  2007 module
                -rwxrwxrwx   1 jan  staff   305 14 Jun  2007 scan.cnf
                It's the missing scan.cnf file with the mount(8) command!
                Code:
                # cat scan.cnf
                # ?X?L???i??scan.cnf?ݒ?t?@?C??
                ##   2002.07.30 A.Miyazaki ?X?L???i?????쐬
                #   2002.12.16 Yuji Ohue ?d?q?F?ؑΉ?
                #   2002.12.20 Yuji Ohue ???????????lj?
                # mount gzromfs ./scan.mod /gwarch/scanner
                # mount gzromfs module/scan.mod /gwarch/scanner
                mount -m >768M gzromfs module/scan.mod /gwarch/scanner
                So I moved that file back into the gwinit.d directory, restarted, and YES! now the "Scanner" button brings up the scanner screen!
                I can just hear the conversation:
                MANAGER: Our employees are spending too much time goofing off, scanning cute kitten photos and baby pictures and such. Can you do anything about that?
                RICOH CE: Sure thing, boss!
                Incidentally, mail began pouring in from the copier about low toner after I restored the scan.cnf file. So if you ever get one that won't email alerts, and by the way, the scanner doesn't work either, they are apparently tied together.
                Thanks for the help and encouragement and for steering me to the SD cards. I've documented the fix here in the hope someone else can use it.
                And if y'all ever need any UNIX help, let me know.
                (PS: anyone know how to log into root access? :-)
                • Orient
                  Thanks Jim
                  I bought a similar unit from BC auction and had the same problem, which is no scan. I did the fix that you mentioned and got the scan working. I have another problem, the unit is protected with admin password. Is there any fix to reset this password?
                    • 37532
                    Originally posted by Orient
                    Thanks Jim
                    There are numerous thread dealing with this question. Do some searching.
                    • sandmanmac
                      • 3981
                      Agreed. In fact, you are the second person today alone, asking the question.
                      http://www.copytechnet.com/forums/ri...-password.html
                      We get a little weary....
                      • Orient
                        Thanks. Supervisor login worked and was able to change admin password
                        • SargeNZ
                          • May 2012
                          • 263
                          This is one of those posts that I am going to mentally file away. Future frustrated tech thanks you.
                          • redneckstylin
                            • Sep 2011
                            • 173
                            sp 5985 001 and 002 switch to value 1
