False toner depleted message on Lanier SP5210 sf
  • sebastianflyte
    • Jun 2025
    Greetings all,
    This thing tells us that it's out of toner and won't allow us to print until a new cartridge is put in. I think there is probably a lot left in it, judging by how many pages we've printed and the fact that the printing quality is fine. I've had this problem on a lot of other printers and there's usually a simple override and, not surprisingly, the printer hums along with the 'depleted' cartridge for hundreds or even a thousand more pages before the toner is truly gone. Does anyone know an override for this for this machine? Any help on this is sincerely appreciated. Thanks so much in advance for any help!
    Cheers.
    • 37377
    Re: False toner depleted message on Lanier SP5210 sf
    If it merely show a toner low message but is still printing, wait until it stops printing.
    • sebastianflyte
      Thanks for the reply. That's the problem, it's stopped and won't start again until it's got a new toner. All the old tricks, taking it out, shaking it, etc are all to no avail. Other printers I've used there were keys you could hold down to get it to accept the toner cartridge that's in it, but I can't figure out a way to do it on this machine. Feels like an aggressive attempt on the part of the manufacturer to get you to buy new cartridges when you don't need them yet...
        • 37377
        I downloaded the service manual and detailed description manual to check on this. Toner near end is determined by the resistance to the agitator plate in the cartridge turning. when the resistance drops, a spring loaded shutter open and and sensor can see the reflective plate. Toner end is 1250 copies later. The model series uses a RFID chip on the cartridge that once the machine determines the end of toner it is stored on the RFID chip and will only be reset by replacing the cartridge.
        • sebastianflyte
          Well, I really appreciate you going to that much effort to check on it. Seems to be no way around it. Blerg.
          Again, thanks.
          • konica7022
            • Nov 2008
            • 132
            i saw the manual and there seem to be alot of stuff about software settings for the toner sensor but i dont know how to set them
            also what if we cover the small toner sensor with black tape and it cant see the reflective plate should it work?
            • COPIERMAN
              • Jun 2009
              • 559
              we have a few of this copiers. Have taken toner cartridges apart and they are out of toner. They are to go 30000 copies at a 5% PERCENT RATE. Most what i see is about 16000 copies of coarse i don't know what my customer are copying. I have done a refill kit and put in toner and replace toner chip. drill a hole on waste side and use a toner vacuum cleaner to remove waste toner out.Then plugged hole Tested and copies look good just need to test in field.
              • konica7022
                • Nov 2008
                • 132
                I have covered the toner sensor with tape, will update when the toner runs auto
                Copier man can you scan and paste the place where to drill whole for waster toner?
                i ordered some rest chips they are one the way and will use any of the sp4001 toner to refill the cartridge sp5200ah
                • sandmanmac
                  • 3979
                  I'm not sure why anyone would drill a hole to empty waste toner
                  You have to remove one of side covers to replace the chip anyway, so remove the other side cover, and then the wiper blade assy (2 screws) and you can dump and vaccum the waste hopper properly.
                  I've only been rebuilding these for a short time, but I always replace the drum, wiper blade, and chip. I've done a dozen or so. The print qualtiy has been very good, but it's true the yields have tended to be 18K at the most. Copierman is overstating saying they're rated for 30K, it's actually 25K, but they fall well short, yet there is always still a fair amount of toner left in the hopper, so I'll be interested to here the results of covering the toner sensor.
                  • COPIERMAN
                    • Jun 2009
                    • 559
                    normally would not drill hole but drum and blade are still good and did not want to damage them buy pulling them out. I am trying to figure out how to up load picture keeps saying bad file when i try uploading it. I drill a hole 1/2 " on waste side about in middle of waste box. then using vacuum cleaner. i take a 1/4 ' tubing stick one in vacuum nozzle and other in waste box move around till almost toner is gone. For here in united states if you have to buy drum /blade /toner and chip and labor to do this is cheaper to buy cartridge. If just toner and chip then cost is ok.
                    • konica7022
                      • Nov 2008
                      • 132
                      ok i removed the old RFID chip with the new one $1.5 replacement chip
                      the cartridge starts to work, tried with 2 cartridges both work fine, covering the toner sensor worked as well it cant detect empty toner any more
                      i was able to squeeze out 1500+ more pages per presumably empty cartridge
                      how ever i used toner t6110d(model mp9002) to refill this cartridge but it ruined both the cartridges, some how this toner wont work properly in this cartridges, after refill there are missing lines and shades while printing
                      or may be i misaligned the cartridge parts while refilling (it has too many parts is too complex)
                      it would be better to buy a compatible toner cartridge for $45 instead
                      • konica7022
                        • Nov 2008
                        • 132
                        [QUOTE=
                        how ever i used toner t6110d(model mp9002) to refill this cartridge but it ruined both the cartridges, some how this toner wont work properly in this cartridges, after refill [/QUOTE]
                        That toner is the problem t6110d will not work in this model i need the right toner to refill
                        • COPIERMAN
                          • Jun 2009
                          • 559
                          Here is link to company that i buy toner for this copier
                          Toner Refill Kits for Ricoh - Fillserv
