problem with ricoh mpw240
  • en.
    • Jul 2014
    • 124
    hi all
    the problem is when i try to make copy or print counter the copy is exit white copy ...i mean there is no text or anything on paper
    then the machine give me sc 402
    best regards
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: problem with ricoh mpw240
    I'm assuming you mean MPW2400.
    Form Goose's Guide:
    B286/B289 SC 402 ID sensor Vsp error: Defective CGB power pack
    B286/B289 SC 402 ID sensor Vsp error: Defective development unit
    B286/B289 SC 402 ID sensor Vsp error: Defective ID sensor
    B286/B289 SC 402 ID sensor Vsp error: Defective MCU
    B286/B289 SC 402 ID sensor Vsp error: Hex screw on drum drive gear not tight, drum not turning
    B286/B289 SC 402 ID sensor Vsp error: ID sensor dirty
    • jdzr
      • 125
      Make absolutely sure you check the drum drive gear set up. Common problem for the setscrew to come loose and the drum will not turn giving you error codes. The machine will appear to function normally except for the blank copies and then give you the error code.
