MPC305SPF SC101
  • Kyokushin
    • Mar 2011
    • 7
    [Error Code] MPC305SPF SC101
    Hi all
    i have here a MPC305SPF with the the error SC101, i changed the Scanner Unit how the describe in the Service manual.
    but the SC101 is still there,i have also changed the BICU, so i was looking where the lamp stabilizer is but in the parts manual and the point to point diagramm i cant find it. Is it in the Scanner Unit?
    hope someone can help me thanks
    Alex
  • Polarbear
    • Feb 2012
    • 1070
    Re: MPC305SPF SC101
    Originally posted by Kyokushin
    Hi all
    Alex
    The service manual of the MPC305 reminds me of the MP161 manual when it was first released.
    There were so many contradicting pieces of information that it left you more confused than helping at all.
    The scanner unit on this model uses LEDs so I do not think that there is a need for a lamp driver board as there is no cathode lamp in it. If fact the scanner shares a lot of parts with the MP301.
    If you say you replaced the scanner unit, do you mean the whole scanner assembly or just the scanner rail assembly (that holds the LED assembly)?
    Press the GREEN button!!
    • Kyokushin
      • Mar 2011
      • 7
      Re: MPC305SPF SC101
      Hi Polarbear
      yes i changed the wohle Scannerunit.
      Now i got it, i used another Scanner unit from another machine and now it works. maybe the first one, witch was new, was broken.........
      Alex
      • mhyrxrew
        Lean on me
        • Jul 2014
        • 3
        Re: MPC305SPF SC101
        hello there! I got the same case on MPC305SPF with SC101, I have already replaced the whole scanner unit but still triggered the same error code, possibility of the 2nd Scanner Unit being defective was disregarded as it came from a working machine.. the manual did not mentioned the BICU board as the source of the problem but I will try with it in case.. any helpful input is highly appreciated.. regards..
