HI
Got this weird problem on a MPC4000 !
Customer called for problems/jams on paper tray1
So I replaced the complete pickup unit-tray 1
After that, it contiunues gives an error on the front door !!
Indicates that the door is open, but the switch is working well (checked SP5803-39)
Even disabled 5508-03 (initiating a call)
When I replaced the pickup unit, the power was on and I had some trouble with
the connector . . . . . could this perhaps trigger a shortcut in the board?
And if so, is it in the BICU board or Controller.
Someone a clue or tip here, given me a headache
Thanks in advance
Thanks in advance
