mp5500 sc402 intermittently
  • vargue
    • Oct 2011
    • 404
    [Error Code] mp5500 sc402 intermittently
    hi fellas this code happend when i do developer adjustment2963 and it's complet.after counter page it's misfeed then pops up sc402 and. on/off machine .machine works fine.but this machine have light copies i changed developer typ24 and seem to me blockbuster then after afew copies 200 or 300 come back again and vsg 3.33 and vasp 0.83 .i replaced used transfer belt but nothing changed.this code never happend during copying
    • 37641
    Re: mp5500 sc402 intermittently
    From Goose's Guide:
    Transfer output error, Transfer power pack defective
    Transfer output error, Check transfer harness and connections
    Transfer output abnormal- Tighten fly wheel screw
    Mulitple SC codes - Check drum shaft flange screw
    Transfer output error - Inspect middle drum shaft screw (loose)
    • bob marley
      • Jan 2012
      • 1339
      Live for yourself and you will live in vain. Live for others, and you will live again
