MP C5501 Finisher
  • ABS tect
    • Sep 2013
    • 511
    MP C5501 Finisher
    We have a MP C5501 and are trying to use a SR3020 finisher on it. What year does the finisher have to be to be compatible, or what does the serial number have to be?
    • 37532
    Re: MP C5501 Finisher
    According to the product support guide the SR 3020 is one of the finishers for use with the MP C5501. You will need a BU 3030 bridge unit.
    • mikedci
      • Jul 2010
      • 227
      The finisher needs 02.090:22 B8045552J firmware released in june of 2010 or later. Firmware modified to support the CPM specifications of the D088/D089.
      Be very careful if you update the firmware for the finisher as there was a pcb cpu change and if you load the wrong firmware you will fry the pcb.
