Ricoh MP C5503 - Black image problem
  • Zaxxon
    • 608
    Hi fellow techs.
    I got this MP C5503 with K- image problem - PDF Scan attached.
    Counter page - OK!
    Logging pages - Background and dev. particles
    Sky Shot CMY - OK!
    Sky Shot K - faint
    Test page color:
    CMY ok, K horisontal ok, K vertical -faint.
    So far I have changed:
    1. K PCU
    2. K-Dev Unit
    3. Image Transfer UNIT (incl. cleaner)
    Have you seen this before?
    Nice day to you all.
    20150326101227899.pdf
    Please start you post with brand, model, problem.
  • UCPrint
    • Oct 2012
    • 24
    Re: Ricoh MP C5503 - Black image problem
    Have you tried cleaning the laser unit? seen this sort of thing on older models like the MPC3500, general rule is if ive changed the drum and dev/unit its normally the laser, let us know how you resolve this one!
    • Zeldaman
      • Mar 2011
      • 946
      • Sashko
        • Oct 2009
        • 110
        No development bias apllied to the development roller.
        • tjvincent
          • 280
          When the dev unit/pcu was replaced did they forget to put the cover on the back with the grounding plate ?
          • Zaxxon
            • 608
            Thats is possible, will go back and have a look.
            Thanks for all you kind help.
              • 37628
              Instead of sky shots, try using the checker flag test pattern.
              • Cipher
                It's not easy being green
                • May 2006
                • 1309
                You had SC361-01 on March 19th & 23rd which is a K TD sensor adjustment error.
                Did you set 3701-003 to 1 and power off before replacing the K dev unit?
                Also check the back plate on the K PCDU, there is a metal voltage strap that needs to be in the correct position for a good contact.
                • Zaxxon
                  • 608
                  I did set 3701 for PCU and later for the dev.unit and transfer unit.
                  But I seriously can't remember if the contact plate was in place... Damn!!!
                  Have orderd HV board and returning to this mashine in about 2 days, hoping that it's a missing back plate though.
                  Thanks to all for your fast and professional help.
                  I will return later with a follow up.
                  • Zaxxon
                    • 608
                    SOLVED - Re: Ricoh MP C5503 - Black image problem
                    This was the answer, the groundplate was missing (But I didn't forget to attach, it was one of my colleagues...)
                    Thanks all
