SC 866 on Postscript SD Card for Ricoh MP C4502
  • AccurateBS
    • May 2025
    [Error Code] SC 866 on Postscript SD Card for Ricoh MP C4502
    SC 866 on Postscript SD Card for Ricoh MP C4502. Does this mean the card is 1) Written for one specific machine 2) data is ruined. Also where can I replace the data on a SD card?
    Specs:
    Postscript3 Unit
    Type C5502
    A1204
    D6455111D
    On the back:
    D080
    St2ca121834
    • 37059
    Re: SC 866 on Postscript SD Card for Ricoh MP C4502
    SAC 866 is an authentication error for the SD card. This means that the SD card is either corrupted or for the wrong machine. You can use application move to copy other applications to the PS3 card if you have more application card than slots. Move cannot write to the PS3 card with an PC as that most likely will corrupt the card structure.
