MP Pro c5100
  • Timmytronic
    replied
    Re: MP Pro c5100
    Originally posted by Tonerbomb
    If it was set to 1 then your machine most likely came from Ricoh as a Fiery equipped unit..... That's what the Pro 5100 was intended to be for. It's a light production unit not an office unit like the c6502/c8002 units.
    Hi
    I think you are right, I do find a lot of printers don't like gaffing with the fiery and all its options and the internal seems pretty good at getting the colours right. I did have one printer who went back to the internal on an older type machine as it was always better. I have ordered the Netware card for it, do you think that will do it?
    Tim
  • Tonerbomb
    replied
    Re: MP Pro c5100
  • Timmytronic
    replied
    Re: MP Pro c5100
    Originally posted by KenB
    Check SP5193-001.
    It should be set to 0 to use the internal controller, 1 for the option external Fiery controllers.
    The Fiery connects to the machine through a second NIC card, which will be right next to the standard NIC. (The secondary NIC is referred to as the Gigabit controller.)
    Sounds like there is a chance that you have NO print controller. For your sake, I hope not.
    Hi. You were right it was on 1 but putting it on 0 has not done it. Rebooted etc but no go so hopefully the netware card will do it. Thank you for the input tho.
  • KenB
    replied
    Re: MP Pro c5100
    Check SP5193-001.
  • KenB
    replied
    Re: MP Pro c5100
    This card is for NETWARE printing only........ The real way this machine is designed to print is with the Fiery E-33B or e-42B....
    WHo does anything with netware anymore??????????????
    Egg-zactly!
    If you order the card, you will be very sadly disappointed. It is simply an option for the internal (GW+) print controller.
    And nobody uses NetWare anymore. I can't even remember the last time I saw it.
  • Tonerbomb
    replied
    Re: MP Pro c5100
    Originally posted by Gamut
    Yep think your missing Netware printing type M2 (D719)
    This card is for NETWARE printing only........ The real way this machine is designed to print is with the Fiery E-22B or e-42B....
  • Timmytronic
    replied
    Re: MP Pro c5100
    ordered!! 😜
  • Gamut
    replied
    Re: MP Pro c5100
  • Timmytronic
    replied
    Re: MP Pro c5100
    Originally posted by Zaxxon
    I can get the information but not until tomorrow.
    Thank you. That would be great. Home now so I won't do anything tonight.
    Have be a good one.
  • Zaxxon
    replied
    Re: MP Pro c5100
    Originally posted by Timmytronic
    I will see if its in the manual but if anyone knows, that would be great.
  • Timmytronic
    replied
    Re: MP Pro c5100
    It is an sp setting, can't remember which but it is more than one sp.
  • Zaxxon
    replied
    Re: MP Pro c5100
  • Timmytronic
    started a topic MP Pro c5100
    MP Pro c5100
    Hi
    I have just got a new Pro C5100 delivered which had done around 300 copies which was great I thought until now I see there is no Printer on the control panel. Is there something I need to switch on in Service mode or is there an SD card I need for Network/Netware like an M2 card? I have checked user tools and there is no Printer there.
    Thanks for any help
    Tim
