MP Pro c5100
  • Timmytronic
    • Oct 2010
    • 249
    MP Pro c5100
    Hi
    I have just got a new Pro C5100 delivered which had done around 300 copies which was great I thought until now I see there is no Printer on the control panel. Is there something I need to switch on in Service mode or is there an SD card I need for Network/Netware like an M2 card? I have checked user tools and there is no Printer there.
    Thanks for any help
    Tim
  • Zaxxon
    • 608
    Re: MP Pro c5100
    It is an sp setting, can't remember which but it is more than one sp.
    Please start you post with brand, model, problem.
    • Timmytronic
      • Oct 2010
      • 249
      Re: MP Pro c5100
      I will see if its in the manual but if anyone knows, that would be great.
      • Zaxxon
        • 608
        Re: MP Pro c5100
        I can get the information but not until tomorrow.
        • Timmytronic
          • Oct 2010
          • 249
          Re: MP Pro c5100
          Thank you. That would be great. Home now so I won't do anything tonight.
          Have be a good one.
          • Gamut
            • Jul 2008
            • 216
            Re: MP Pro c5100
            Yep think your missing Netware printing type M2 (D719)
            • Timmytronic
              • Oct 2010
              • 249
              Re: MP Pro c5100
              ordered!! 😜
              • Tonerbomb
                AutoMajical Resolutionist
                • Feb 2005
                • 2589
                Re: MP Pro c5100
                This card is for NETWARE printing only........ The real way this machine is designed to print is with the Fiery E-22B or e-42B....
                WHo does anything with netware anymore??????????????
                Mystic Crystal Revelations
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3945
                  Re: MP Pro c5100
                  Originally posted by Tonerbomb
                  This card is for NETWARE printing only........ The real way this machine is designed to print is with the Fiery E-33B or e-42B....
                  Egg-zactly!
                  If you order the card, you will be very sadly disappointed. It is simply an option for the internal (GW+) print controller.
                  And nobody uses NetWare anymore. I can't even remember the last time I saw it.
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3945
                    Re: MP Pro c5100
                    Check SP5193-001.
                    It should be set to 0 to use the internal controller, 1 for the option external Fiery controllers.
                    The Fiery connects to the machine through a second NIC card, which will be right next to the standard NIC. (The secondary NIC is referred to as the Gigabit controller.)
                    Sounds like there is a chance that you have NO print controller. For your sake, I hope not.
                    • Timmytronic
                      • Oct 2010
                      • 249
                      Re: MP Pro c5100
                      Originally posted by KenB
                      Check SP5193-001.
                      Hi. You were right it was on 1 but putting it on 0 has not done it. Rebooted etc but no go so hopefully the netware card will do it. Thank you for the input tho.
                      • Tonerbomb
                        • Feb 2005
                        • 2589
                        Re: MP Pro c5100
                        If it was set to 1 then your machine most likely came from Ricoh as a Fiery equipped unit..... That's what the Pro 5100 was intended to be for. It's a light production unit not an office unit like the c6502/c8002 units.
                        • Timmytronic
                          • Oct 2010
                          • 249
                          Re: MP Pro c5100
                          Hi
                          I think you are right, I do find a lot of printers don't like gaffing with the fiery and all its options and the internal seems pretty good at getting the colours right. I did have one printer who went back to the internal on an older type machine as it was always better. I have ordered the Netware card for it, do you think that will do it?
                          Tim
                          • KenB
                            Geek Extraordinaire
                            • Dec 2007
                            • 3945
                            Re: MP Pro c5100
                            Hi
                            Tim
                            You're not listening.
                            The NetWare card WILL NOT HELP if there is no print controller to begin with.
                            Sound like it had a Fiery originally, but you don't have it. (A Fiery is a totally separate box) which connects using a crossover cable and a second Ethernet port on the copier. That card normally ships with the Fiery.
                            BTW... The Fiery is far superior to the internal print controller. Better utilities, color control, etc..., especially on a higher end machine like this.
                            I do agree that Fieries are a bit of a waste on small machines, and can be more of a hassle than anything, but not so on a 5100. I am not a fan of putting a Fiery on a "business color" unit, where the most complex or critical print jobs it will ever see are from Word or PowerPoint.
                            If you are to get the best performance out of this machine, a Fiery is essential. The internal controller is offered as a lower priced alternative, and is sometimes a good fit for those who don't demand the higher end features.
                            • Gamut
                              • Jul 2008
                              • 216
                              Re: MP Pro c5100
                              KenB I think the UK Salesforce see's this differently, I don't have one ProC5100 or variant using a Fiery.
