MP Pro c5100
Re: MP Pro c5100
Hi.
Is there anyway of knowing if the controller is installed? It has all the stuff at the rear and Ethernet socket etc so I assumed the controller was there.
I feel dimwited a little on this as I know networking and fixing these puppies but never came across this where there is no printer showing.
Once I have got the netware card I was hoping to install it and it would do the job but it does not sound like it will hey.
Thanka ka for getting back.Comment
Re: MP Pro c5100
The presence of a network jack does not indicate that there is a printing option installed.
If you print a firmware report, it will show the versions of the print components, if installed.
If they show as "- -" (2 dashes), it's not there.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
Re: MP Pro c5100
You're getting some bum information here. All Pro C5100 supplied in the UK have the GW controller but it is disabled because most have a Fiery connected to them. On the one occasion I installed a C5100 without a Fiery I followed the install procedure for the Fiery in reverse, chek SP5895, your machine is probably set to 1, set this to 0 and reboot machine.
The page from the E22B manual is attached.C5100 print setup.pdfComment
Re: MP Pro c5100
The page from the E22B manual is attached.[ATTACH=CONFIG]28622[/ATTACH]
Sorry for any misguidance.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
Re: MP Pro c5100
right on !!!!!!!!!Mystic Crystal RevelationsComment
Re: MP Pro c5100
Hi. Thank you for the info. It worked as soon as I rebooted it. Really appreciate it, I was hoping it was a case of switching it on in SP mode. Even tried a Postscript card and it worked perfectly. Let's hope the machine does and the latest firmware helps with the toner collection filling in a second :0)
Have a good day and thanks Ken and Gamut also, it all helps with our inputs for anyone else out there.Comment
Re: MP Pro c5100
Re: MP Pro c5100
Hi. I have a problem with the pro c5100. I managed to get the printer showing on the display, using the built in rip, as advised and today went to check if the machine prints from a network, got an IP address but Ricoh don't have any printer description files that match the 5100 as it assumes it has a E22b Fiery inside for example so Ricoh only show it in controllers and not in MPC machines even tho it has a GW controller only now.
As as this is the same machine in a way as the MPC 6502 would that Printer description file work as that is available at Ricoh?. Any advice would be great.
Thanks. Tim.Comment
