Error Code SC 558
  • jc1print
    • Nov 2014
    • 28
    [Error Code] Error Code SC 558
    Can ANYONE ASSIST WITH THIS PROBLEM THE MACHINE WARMS UP AND THEN THE NEW MOTOR REPLACED BEGINS TO TURN AND THEN IT STOPS AND ERROR CODE COMES UP I CLEANED THE OIL SUPPLY UNIT BUT DOES IT HAVE TO BE REPLACED COMPLETELY TO RESOLVE THIS
    • 37323
    Re: Error Code SC 558
    We cannot help you with this because you failed to give us the model.
    • jc1print
      • Nov 2014
      • 28
      SORRY PRO C720
      • Gary Bowen
        Bowdog
        • Mar 2008
        • 250
        I recently had the same error on a PRO C900 and it required the complete 400K Fuser PM Kit (742PMG178400K). Sorry, there was no other fix (and the kit is $1200 plus through eSales). Did you put the "silver" and "black" tension springs back in the right place? Try starting the machine up without the Drive Coupling for the Oil Supply Unit in place (this might put too much strain on the Fusing Belt Drive but might confirm where your issue is).
        • jc1print
          • Nov 2014
          • 28
          Can u send me the website info for esales please so i can review the parts of the fuser
