Ricoh 2090 duplex jam 073
  • Arshalok
    • Jul 2025
    Recently one of our copiers (Ricoh 2090) started to have a problem with jam 073. I don't see any delays. Also changed the main clutch and the solenoid reverse feeding roller. Maybe you can help me to solve this problem cause I am stuck right now. I will greatly apprieciate any help.
  • allan
    RTFM!!
    • 5462
    Re: Ricoh 2090 duplex jam 073
    What's the meter reading.
    Whatever
    • Arshalok
      Sorry, but how can I check meter readings in ricoh 2090?
      • allan
        RTFM!!
        • 5462
        Ok mmm... look for an operation manual.
        Are you a tech or a end user?
        Whatever
        • Arshalok
          English is not my native language. Sorry, I didnt understand you correctly. the read meter is about 7mil iirc. Printers in co I am working are very raddled.
          • allan
            RTFM!!
            • 5462
            That is a lot of prints. Take a look at the diameter of the transport rollers.
            Whatever
            • kwehner
              • Mar 2009
              • 47
              There are two rubber cushions on the frame for the duplex entrance guide and I have had the front one fall off and cause intermittent jams. The paper was skewed in the duplex when it jammed.
                • 37503
                Not for a Production machine. The Aficio 2090 is a Production Machine, the predecessor to the MP 9000.
