MY C3003
  • h2ackski
    • Mar 2015
    • 11
    MY C3003
    I am unable to access Web image monitor. The machine can copy print, fax and scan. It has been working for the past few months, but the Web image monitor quit working. All settings have been checked and firmware is update. What next?
    • 37469
    Re: MY C3003
    Please provide us with a list of the settings that you have checked. You may have missed something and with out a list of what you have done, all we can do is guess.
    • h2ackski
      • Mar 2015
      • 11
      Re: MY C3003
      I have made sure no duplicate IP addresses I have made sure no wireless settings are on. 5985-001 is set to 1 The latest firmware has been updated on the machine
      • rsyarcia
        Hair Straightener Tech
        • 711
        Re: MY C3003
        have you tried other web browsers like chrome or firefox? have you tried accessing the WIM from other PC?
        Nobody is perfect..
        • h2ackski
          • Mar 2015
          • 11
          Re: MY C3003
          We have tried from several different PC's. All can ping but can't access WIM. We have tried chrome, firefox and internet explorer. no luck
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            Re: MY C3003
            What is the http response code you recieve? Or, does it just timeout?
            If the error is 403, you most likely have an access range set. If the code is 404, you could have incorrect IP and subnet settings, or the controller settings could be corrupt.
            Use telnet to log into the machines IP address and perform an "access flush".
            Also, try setting the machine to DHCP and make sure the DNS is also set to Auto-Obtain, let the machine do a soft-reset, then take note of the new IP address and use that to access the WIM. Or, take a note of all interface settings from User Tools > System Settings > Interface Settings, and perform a memory clear on NCS / NIB only. You will need to re-enter the network settings after a reboot.
            More info on access flush: access
            • Laniertech146
              Re: MY C3003
              Have you tried restarting the unit?
              Also, if anyone enabled the AirPrint feature, you'll need to do https instead of http.
              • h2ackski
                • Mar 2015
                • 11
                Re: MY C3003
                We have restarted it many times. AirPrint not enabled.
                Thanks,
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Re: MY C3003
                  Try connecting to a PC with a crossover cable.
                  Could be a network thang blocking access.
                  • DH1980
                    • Mar 2009
                    • 52
                    Re: MY C3003
                    We had an account that could not see WIM because of anti malware software. We disabled it and the WIM worked fine.
                    • h2ackski
                      • Mar 2015
                      • 11
                      Re: MY C3003
                      Thanks to all! It was solved with a new controller board
                      • teebee1234
                        • Jul 2008
                        • 1670
                        Re: MY C3003
                        Seems like overkill for a problem that most likely could have been fixed on the software/firmware side. But it works now so that's what counts.
                        • h2ackski
                          • Mar 2015
                          • 11
                          Re: MY C3003
                          I had tried all firmware and software ideas that I have ever heard or was told. Nothing else solved the problem. Ricoh Tech support had me try lots of stuff none of which worked either. At some point you have to make it work to keep the customer happy.
