3245c color offset
  • T911
    • Jun 2007
    • 628
    3245c color offset
    cleaned id sensors, transfer metal rollers, belt is in good shape, performed sp5993-2 which failed. i remember reading a while ago on changing some settings that worked on another 3235c for me but just cant remember the changes i made. I think they were in the 2's. any help appreciated. black and white is fine just color is the problem. print or copy. thx
  • sandmanmac
    • 3979
    Re: 3245c color offset
    Hope this helps.
    I apparently used it myself at some point, because I scribbled a few notes, etc., that are completely irrelevant
    However, I don't remember much else to give you any advice
    AF3245C -Colour Alignment Adjustment.pdf
    • T911
      • Jun 2007
      • 628
      Originally posted by sandmanmac
      Hope this helps.
      [ATTACH]28753[/ATTACH]
      thanks much.
      • Gift
        • Mar 2011
        • 2458
        plenty threads about this do already exist here
        • freginold
          • Sep 2010
          • 102
          resetting the transfer motor speed sometimes help. Also have had to replace several lasers on those models for offset colors.
          Config page instructions for copiers, printers, & fax machines
