Hold Print confirmation screen
  • ricmartinho
    • 142
    Hello!
    Is there any way to disable the confirmation screen that shows when a print job is released at the machine?
    This last screen it's a bit unnecessary and the customer would like to get rid of it. Is there any way do that?
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3946
    Re: Hold Print confirmation screen
    Originally posted by ricmartinho
    Hello!
    [ATTACH=CONFIG]28755[/ATTACH]
    Yeah. Don't send to Hold print.
    • ricmartinho
      • 142
      I don't think they'll buy that...
      • mrwho
        Major Asshole!
        • 4303
        Mascan42
        Ibid
          • 34934
          In Print Server Properties turn off (Uncheck) Show informational notifications.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3946
            Is this setting on the copier, or on the Windows print server?
            AFAIK, the screen is required to be able to release "hold' print jobs. If not there, I would think it defeats the purpose of using "hold" print in the first place. Hence my original, somewhat snarky remark.
            Once the job gets to the machine, regardless of its path, it needs to be released by touching the screen, at least in some manner.
            Maybe I'm missing something? Wouldn't be the first time...
            • mrwho
              Major Asshole!
              • 4303
              That screen is an additional screen that shows up after you select the job and press "print", and it allows you to change quantities and other settings. The customer doesn't need it because he already set everything up on the driver properties.
              Mascan42
              Ibid
