R3350 bridge unit d363
  • Dshaffer
    • Jan 2015
    • 12
    Can anyone send me a parts Manual or help me find the parts #'s for these to items for this bridge unit?
    PCb and dc motor for bridge because of code J026
  • laitang
    • Nov 2012
    • 627
    Re: R3350 bridge unit d363
    Did you mean Bridge Unit BU3020 (d368) use for ricoh mp3350?
    • Dshaffer
      • Jan 2015
      • 12
      Yes that is what I am looking for
      • freginold
        • Sep 2010
        • 102
        bridge PCB = B417 5146
        bridge DC motor = B417 6283
        Config page instructions for copiers, printers, & fax machines
        • Dshaffer
          • Jan 2015
          • 12
          thank you very MUCH!
          • mikadonovan
            • May 2008
            • 2931
            Just a FYI, I have never had to replace either of those parts on any bridge unit. However, there is a safety switch on the entrance area guide (the one you lift up to remove a jam) that goes south and causes intermittent misfeeds.
            NEVER ASSUME ANYTHING
            • Dshaffer
              • Jan 2015
              • 12
              this is very helpful and I will make sure you get one for my jamming.
              thank you!
              • Dshaffer
                • Jan 2015
                • 12
                thank you!
                one more thing , where is the switch located?
                • freginold
                  • Sep 2010
                  • 102
                  It is the cover switch that tells the machine whether the bridge cover is opened or closed. When you open the bridge cover, you should see the small black switch on the op side of the bridge unit. I've had these switches go bad A LOT. Part #AW500023.
                  • Dshaffer
                    • Jan 2015
                    • 12
                    thank you everyone for your assistance!
