Aficio 2075 Fusing Problems
  • Zia Graphy
    • Aug 2012
    • 17
    [Misc] Aficio 2075 Fusing Problems
    Hi everyone.
    I'm working on a Ricoh Aficio 2075 with some fusing problems. The SC History shows recent SC545 (Overheating code, possible thermistor) and SC555 codes (Fusing lamp error or thermistor). When inspecting the machine I found that one of the 192C thermostats was blown. Thankfully I had a replacement thermostat. Upon running test copies I found that after about 7 copies the toner would no longer fuse to the paper and a jam would occur due to the build up of loose toner on the hot and pressure rollers. The jam occurs before the fuser throws a fuser code, so I haven't been able to reproduce the SC545 and 555. Checking the fusing temperature display during test copies reveals that the temperature drops from ~195C down to ~144C during a run of 10+ copies before the machine jams.
    The thermistors are clean, and the hot roller and pressure roller are in good shape. The lamps show continuity and light up appropriately during test copies. I don't know how long it's been since any of the fuser parts have been replaced. I suspect that the thermistors might be the problem so I've ordered replacements. However during test copies I also got an SC569, which is a pressure roller release motor error. This threw me for a loop.
    I inspected the pressure roller release mechanism and position of the pressure roller and everything appeared to be normal - none of the gears transmitting drive from the release motor have any damage or wear and the cam rotates normally and the home position sensor is clean and correctly identifies the home position. The code has not returned. I only mention this because the SC569 seemed totally unrelated to the other codes which will hopefully be fixed by replacing the thermistors.
    Has anyone run into multiple fusing codes like this or have any idea if the problem could be deeper than a couple of thermistors - like a controller board or something? Is there anything else I should think about replacing while I'm at it? Thanks for your consideration.
  • allan
    RTFM!!
    • 5462
    Re: Aficio 2075 Fusing Problems
    Check to see if there is proper pressure between the rollers.
    Whatever
    • rthonpm
      • Aug 2007
      • 2860
      Check and see if the machine has the updated thermistor brackets from a few years back. They bring the thermistors into closer contact with the heat tube.
        • 37631
        Check that you have the proper lamps. If the 550W lamp, applies heat to the ends of the hot roller, is a 220 volt lamp temperature of the ends will drop during copying. This will also happen if the connections of the 550W lamp and the 280W lamp are reversed.
        • Codex
          • May 2008
          • 705
          I had some issue with the Fusing Unit conector, (Piece of paper inside)
          Memento Audere Semper
          • Zia Graphy
            • Aug 2012
            • 17
            Thanks for the ideas everyone. Pressure between the rollers looked good when I was out there. Not sure if the new style thermistor brackets are on the machine, but I'll check that and double check the lamps to see if they are the correct wattage and that they are plugged in correctly.
            I'll let you guys know what I find when it is fixed!
            • Zia Graphy
              • Aug 2012
              • 17
              My parts catalog shows 2 different thermistor brackets for that model B140 4196 Inner Back Thermistor Bracket and B140 4197 Middle Thermistor Bracket.
              Are those the up to date version?
              Replaced the thermistors and hot roller today with no change. Checked the fusing lamps as slimslob suggested, and they are the correct lamps - there's a 650W, 550W and a 280W. The green connects to green, blue to blue, and white to white. Out of curiousity I checked the fusing temperature on a known working machine and saw that the temp does drop down to ~145C - 150C during the course of copying - so it looks like those temps are normal. I also checked the power outlet the machine is plugged into and everything checks out normal there, even in the middle of copying.
              Now I'm actually at a bit of a loss. It doesn't seem like the temperature is a problem since the thermistors, hot roller, thermostats, and lamps are good - yet the toner is not fusing to the page as if the temperature is dropping during a run of copies. I double checked and confirmed that the pressure roller is being engaged by the pressure roller cam. The cam turns and the little flag stops when it reaches the home position sensor. Scratching my head now. Any thoughts? Oh, and the machine is running OEM toner, it's at about 1.6 million copies. And the stuff that's rubbing off of the page definitely feels like toner, not developer.
              Thanks for all the help thus far! You guys are great
              • Tonerbomb
                AutoMajical Resolutionist
                • Feb 2005
                • 2589
                Sc 555 is a huge nuisance code, the 569 code usually comes from a broken sensor or connector that wasn't unplugged before removing the fuser. Also if the lamps are not in the correct positions in the lamp holders you can have codes or bad fusing. Also clean the pins and springs on the machine side of the fuser connector in the rear of the machine. again power,power,power............
                Mystic Crystal Revelations
                • mikadonovan
                  • May 2008
                  • 2931
                  You ought to go ahead and rebuild the fuser to start.That way you know for sure that the hot and pressure rollers are in good shape, instead of chasing your tail assuming they are ok. The only poor-fusing issue I have had on this model was because of non-OEM toner, which you said was not the case. The toner I refer to worked fine in the 2051, but the 75 cpm speed of the 2075 wouldn't fuse the aftermarket toner properly.
                  NEVER ASSUME ANYTHING
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    Check those lamps right where the glass meets the white plastic.
                    This isn't exactly a modern box and those lamp ends can get brittle and crack or break and cause intermittent issues...especially when you're trying to wrestle them back into the brackets at either end.
                    • tufbnme
                      • 493
                      Here are the part #s for the brackets. Replace the thermistors as well, they can look good but still be bad. (like an old girlfriend)
                      Old P/Ns - B1404196/7: 14.8 mm
                      New P/Ns - D0624196/7: 15.3 mm
                      • tufbnme
                        • 493
                        Here are the thermistor #s
                        OLD PART NO. NEW PART NO.
                        AW100108 AW100131 Thermistor: Fusing: Middle
                        AW100109 AW100132 Thermistor: Fusing: Inner Back
                        • Zia Graphy
                          • Aug 2012
                          • 17
                          Okay here's the update. I went ahead and rebuilt the fuser. New hot roller, pressure roller, pressure roller bearings, lamps, thermistors, and thermistor brackets. The lamps have updated part #s and they look a little different than the old ones. AX44 0215 - 120V 280W, AX44 0304 - 120V 650W, AX44 0305 - 120V 550W. Also the brackets have new part #'s. D062 4196 - Back, D062 4197 - Middle.
                          After replacing the parts I still have the same problem, fusing temp drops to 138C over the course of 25+ copies. So I think maybe the PSU isn't supplying enough power to the lamps or perhaps the BCU isn't giving the 5V signal to the PSU. I replace the BCU and PSU (boards off a used machine) and still no change. I did swap the EEPROM on the BCU as per the service manual. Still no luck. My next course of action is to check the connector at the back of the machine where the fuser unit plugs in, and then start checking connections from there to the BCU to look for breaks. I can't believe this problem persists. I'll post the solution when I figure it out in case anyone else runs into this.
                          In the mean time I'm certainly open to any suggestions!
                          Could this be a "frimware" problem? My current versions are:
                          System/Copy B1415211J 1.22.1
                          Enging B1635127 5.20a:36
                          • withnail
                            • 59
                            If there are 3 lamps on this fuser check that one of the filaments isn't broken. I've had similar issues where the fuser warms up enough with one lamp blown but after a couple of days gave the same code you're having.
                            • mikadonovan
                              • May 2008
                              • 2931
                              There is a service bulletin out on this model for SC555's, and part of it suggests to shim the connector on the fuser side with washers for better contact, or replace it.
