Ricoh MP C5501 w/50k...Turd at any count or did I find me a diamond?
  • Foo
    • Nov 2009
    • 199
    My resale wholesaler called me with an MP C5501 with 34k B/W and 16k color...50K total copies.
    I have little experience with this box. I'm mostly a B/W guy.
    I have a customer pushing 150k a month and is interested in a faster color machine (currently 35 a min color).
    So with a 50K meter am I looking at an old dinosaur or a decent piece of equipment that my customer will appreciate?
    Does it have any issues I need to watch out for?
    Thanks again for your time!
    Jeff D.
    STL
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh MP C5501 w/50k...Turd at any count or did I find me a diamond?
    50k is nothing to these machines. Their avg. monthly volume is rated at 12k, with a max of 50k.
    Black drums are expensive, colour drums can be replaced with older D0292256, with removing a pin on the connector, swapping a wire, and removing a pin inside the machine (see drum cheat sheet).
    Fusers are pretty solid, haven't had any problems with them at all.
    Drum Cheat Sheet.pdf
    • turbojetboy
      • Aug 2009
      • 279
      Mpc 5501 are in my opinion best colour midrange mfd that Ricoh has made to date, super reliable easy to fix and parts run to PM and then usually way past.
      • tufbnme
        • 493
        Love em, great machine. All the components will run well after their yield.
        • ptrflrs
          Glorified Parts Swapper
          • Dec 2010
          • 192
          Have seen a C5501 fuser do a million clicks with some noise from the bearings but still. Toner pumps go out more often. Usual black and color drum units will need replacing. In my experience any ricoh xx01 is better than any xx02 or xx03 so far. Firmware update helps.
          jesus loves you! (everyone else thinks you're an assh*le)
          street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
          Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
          • redneckstylin
            • Sep 2011
            • 173
            [ATTACH]28809[/ATTACH]
            d089 blk pcu
            b224-2042 grind and brak pin off
            • Zaxxon
              • 608
              Originally posted by redneckstylin
              d089 blk pcu
              Can You please explain this og even better a picture of what modifications to perform?
              Thanks in advance.
              Please start you post with brand, model, problem.
              • Iowatech
                Not a service manager
                • 3930
                Thanks in advance.
                This might help:
                http://www.copytechnet.com/forums/ri...c4502-pcu.html
                • Zaxxon
                  • 608
                  Originally posted by Iowatech
                  As I understand, there is no replacement (midified) version for the Bk PCU?
                  • allan
                    RTFM!!
                    • 5462
                    Will not live to long doing 3 times the recommended max yield.
                    Whatever
                    • Klydon
                      • Mar 2009
                      • 243
                      +1
                      5501 is a good box, but not running 150K a month.
                      • rosspt
                        • Mar 2012
                        • 92
                        I think there must be a mistake on the monthly volume. 150K per month? A pro C5100 is 20K average with a max of 150K per month. A pro C651 is average 50K and 180K max per month. You might get away with a c720 average 60K and max 190K per month but you are going to be doing early pm's constantly every month. Doesn't sound right to me.
                        • Foo
                          • Nov 2009
                          • 199
                          Well I thought that was excessive also.
                          So after my original post I went back and called them, and sure enough
                          she had added the extra 0 to make it 150k per month. LOL so in reality
                          we're talking 15k a month.
                          I went and serviced the C5501 on Thursday. Super clean, not one issue at all.
                          Ran a alot of copies through and never saw a flaw. Color seemed off so I ran the calibration routine.
                          That fixed the color tones.
                          Oh yeah... It only has 40K total. 24k b/w, 16k color.
                          Thanks for all the interesting info about using cheaper cartridges.
                          Jeff
