MP2001 screen disappears
  • burocal
    • Jul 2025
    [Misc] MP2001 screen disappears
    hello
    here's my problem
    my RICOH MP 2001 sometimes when I press a function key the screen does not display all options. there just up written "ready to copy" or "ready to scan" by function and the rest of the screen is gray nothing can select as the buttons as duplex, reduction, expansion, address book disappeared. this problem is random occurs for 5 minuntes then disappears.
    someone would have already had it that worries?
    thank you
    • 37491
    Re: MP2001 screen disappears
    The only possibility that I can think of would be that you had logged in to User Tools as admin and have not logged out. Admin is has rights to configure the machine but not rights to use the machine.
    • Zeldaman
      • Mar 2011
      • 946
      • engineers
        • 51
        Assuming this is a mp2001SP with the newer op panel, maybe its the button at the bottom right that enlarges the screen. You lose most of the options that you described. If its pressed again all back to normal.
        Most customers struggle with that button
        • PA3040
          • Jun 2014
          • 171
          If this is MP2001L relapse the op panel
          • burocal
            hello
            thank you for your reply I will test and tell you if it works
            thank you
