MPC 4500 jamming issue
  • tibbs
    • Aug 2008
    • 225
    Hello, I have an mpc 4500 that keeps jamming near the fuser area and sometimes in the fuser. There is no error codes with the jams. All the pick-up / separation rollers are good. I have checked all the sensors around the fuser area and also the fuser and decoder. Any help will be much appreciated.
    Regards
  • Zeldaman
    • Mar 2011
    • 946
    • Bantams
      • Jun 2012
      • 603
      Re: MPC 4500 jamming issue
      Check the paper exit unit the bearings on the shafts can seize up after time causing intermittent fuser / exit Jams
        • 37481
        Check the SMC data log. If there is no plotter jam history, check the total for jam at power on. A door being opened and closed while paper is moving through will cause a jam at power on. Usually it is a bad door switch. If it has a finisher, replace the door switches on the bridge unit.
        • tibbs
          • Aug 2008
          • 225
          Zaldaman , whats the PTR and where does it sit.
            • 37481
            Paper
            Transfer
            Roller
            • NeoMatrix
              Senior Tech.
              • 3513
              Check the brigde unit switchs they might be toggling? ...
