sc440
  • vargue
    • Oct 2011
    • 404
    [Error Code] sc440
    hi fellas this code reveled after unknown time.and when pops up a3 or a5 papers defferent measure get out weird thread ???? any clue
    • 37652
    Re: sc440
    Can we have a model or product code?
    • fritzyas
      • Jul 2011
      • 73
      Re: sc440
      If this a 40 CPM machine you need to replace the power pack. Encountered this with a NRG MP 4000
      • vargue
        • Oct 2011
        • 404
        Re: sc440
        my apologies model mp9000
        • Moza
          • 232
          Re: sc440
          Check the Transfer unit connector and also clean all rollers and terminals
          • fbkhan3
            • May 2012
            • 421
            Re: sc440
            This one is Main Motor Lock or Drive Mechanism overload,you need to make sure things that are associated or driven by main motor are not overloaded or broken.gears,Recycling,coils,Drum etc.
            • Moza
              • 232
              Re: sc440
                • 37652
                Re: sc440
                Black lead on pin 6 of the connector is known for breaking. Will cause the error.
                From Goose's Guide:
                Transfer output error - Check for pinched harness at transfer connector
                Transfer leak - replace transfer power pack harness cn 21 pin 6 open
                Transfer output error - Transfer power pack defective
                Transfer output error - Replace Arcing Pre Charge Unit B2342140
                Transfer output error - Replace BCU board
                • francisco
                  • Nov 2009
                  • 168
                  Re: sc440
                  try to rotate developer unit ,some bearings off the magnetic rollers ahve to be changed, in the worse case change all developer unit
                  • fbkhan3
                    • May 2012
                    • 421
                    Re: sc440
                    [ATTACH=CONFIG]28856[/ATTACH]
                    my apologies, i misread the Model and went through looking for MP 9001 Service Manual.Drive overload.jpg
                    Thanks for correction.
                    Regard's
                    • vargue
                      • Oct 2011
                      • 404
                      Re: sc440
                      trasfer belt is worn .
