R-1035
  • tcypy1961
    • 773
    R-1035
    Having to keep this copier on pixel (SP2208); have replaced ID sensor twice one new (not sure if it was for this model or 2035) today replace BCU, SBU, and high voltage PCB's yet can't get SP 3001 to fall below 200(drum is new) usually will code out with SC355; drum ground is good. ????? Thanks!!!!
    • 37447
    Re: R-1035
    Is the drum Ricoh or after market? The value of SP 3001-001 has to do with the reflectivity of the bare drum surface. Have you also check the ground for the development unit? If fact. have you checked anything having to do with the developer?
    • Iowatech
      Not a service manager
      • 3930
      Re: R-1035
      Are you using the correct toner for that machine? The toner for the 35/45 CPM machines went through some rather vast changes back in the day when that machine was new.
      As a probably stupid side note, when was the last time you replaced the developer in that machine, and what type of developer did you use then? Sorry.
      • nodle
        • 142
        Re: R-1035
        I have seen the toner motor cause this problem in the past.
