MPC2800 with SC540 & SC565
  • GeorgeBest
    • Jul 2009
    • 526
    Hi,
    customer called for an SC540 (fuser exit motor?)
    did not have an exit motor, but another fuser unit in the car.
    So I swapped the fuser, it run but 1 hour later customer called for SC565 !! (Not sure if fuser was allright)
    Returning tomorrow, but is it the fuser or the exit motor . . .?
    anyone? Thanks in advance
  • skynetto
    • Sep 2012
    • 257
    Re: MPC2800 with SC540 & SC565
    Code:
    SC565
    Pressure roller fusing lamp consecutive full power
    The pressure roller-fusing lamp stays ON for 120 seconds or more while the fusing
    unit is in the ready condition,.
    โ€ข Broken pressure roller fusing lamp
    1. Replace the pressure roller fusing lamp.
    2. Replace the PSU.
    • copy@service
      • Sep 2014
      • 2
      Have had the pressure roller thermister cause this.
      • Codex
        • May 2008
        • 704
        Had the same problem (sc565), in my case it was the pressure roller thermostat (blown).....the problem is that the fuser roller heats up the pressure roller and the machine works for a while without problems......, (try to disconect the thermostat to believe...)
        Memento Audere Semper
